I wanna wish you all the best of luck. Surgeries do sux.
Thanks. So far its feeling better so lets keep fingers crossed!
Get different plastics to trim
someone needs this....southern Missouri, out of major rust belt.....
https://springfield.craigslist.org/cto/6044414194.html
I'm actually looking at getting these tires. Only 135 shipped, 10lbs lighter than mine and seem to have good reviews.
Sent from my HTC6525LVW using Tapatalk
Amazon prime. 2 day tire delivery. I was looking at your Goodyear but these are cheaper. For a wheeling rig I'd keep the Treadwright tires but for DD I want something litter and better wearing.
I have the older A/T Treadwrights in a load range E on the Expy, them things wear like iron. They do flat spot a touch when it's really cold.Stay away from mastercrafts then. Buy a better tire if you are worried about wear. Or an AT.
Mastercrafts tires have been terrible since they changed over the the AXT ,MXT, CXT design. They will wear worse than your Treadwrights easily and they will be much louder on the road. if you don't rotate them every2-3k miles max you are going to hate them.
I suggest cutting the factory plastic pieces.
If that is 3" lift equipment, once you mount those tires, my guess is they will only be around 30" tall so you'll be fine.
Mastercrafts run on the small side. Going to be a nice setup
Passed the FAA pilot's test!!!
mac 'legal to fly' gyvr
Before Josh chimes in, add for the day
Where is this cheesey? Looking at possibly buying another jeep right nowsomeone needs this....southern Missouri, out of major rust belt.....
