kmanxj5050
- Reed City Michigan
Another one for you guys. Drywall or osb?
I think there should be a test everyone has to pass quarterly to use the internet, and it should be controlled by the gov.![]()
4 foot fluorescent is what I have, like Tyler said go with a quick starts. You can pick them up at Menards for less than $20 each
Not to be a pain in the ass, but there is a chance that if you put up OSB, and you ever sell the place, you may be required to either cover it with drywall or take it down, especially if it is attached to your house According to building code, OSB must be not be left exposed. That said, the walls of my shop are exposed OSB and I am going to cover the walls in my new two car garage with OSB. I just want you to know what risk there is.
For sure. I also thought about doing white barn steel in the roof if I did fluorescent lighting. It is super easy to put up and way cheaper than buying osb. Plus it would help with the light.
just replace your existing fixtures bulbs with LED ones.
You'll have to wire 110v to the tombstones and delete the ballasts. Simple, takes 15 minutes per fixture.
You'll have brighter instant on lights that you don't dick with for 10 years, and no fluorescent flicker.
honestly if you put up fluorescent lights these days with the prices of LED ones, you're an idiot. You can pick up ready to go LED fixtures for less than $30 these days, and retrofit tubes are less than $12 a pop if you go that route and update existing.
