emptypockets86
- Sedona, AZ
Ah-ha! So AMC did the wiring in my attic!
Looks legit!
My no start was a bad nss. Derp.
Decided to test the arb air pump this morning on the way to work to make sure everything was working for the clean up.....flip the switch and it didn't pump up.....
You know if you ran autolockers this wouldn't happen. If it comes down to it, you could strap your welding gas tank in the back and get some adapters.
Pre heated the jeep this morning, 27* out and i had to throw the boys in there so i wanted it to be a little warm for them. when i turned it on i remembered that at WF my blower got stuck on defrost only.
Starting to think budget beater again.
I have all the parts, you assemble
Wife keeps hinting toward a car or van instead of the XJ![]()
Which means you get the XJ all to yourself!![]()
Don't ya hate that. Mine was doing that right before I got rid of it.
You're not required to attach the wires to anything, that's why you can just bore holes in studs and feed wire through them. It's definitely a mess but it's probably to code.
I even see a lot of yellow and orange wires, so they're at least using lower gauge wire for higher amperage circuits.
I'm waiting for Ken to chime in, but he probably still doesn't have electricity :shhh:
Heat control stuff is vacuum operated. Most likely a leak somewhere in the line that goes to them.
