- bourbonnais IL
My advice is to pull the carrier from the housing, pull the locker out and put the spider/side gears into that carrier, and reinstall the same carrier. Do not just swap the carriers because unless you are extremely lucky you would have to re-set the backlash on the gears since each carrier is a little different and they probably have different shims.
Or if that's what you meant, then ignore me, you got this![]()
Good point i didnt think of any of that.
