Got a couple issues with the 5.9, wondering if anyone has any thoughts. Yes this is the important thread and yes this is tech. Sue me
When coming to a stop, the brakes work great. As soon as you are almost stopped, the abs seems to kick in for no good reason and the pedal sinks. It still stops, but is an odd not normal feeling. Any thoughts? Should be a similar abs set up to the XJ.
Sensor going bad and computer thinks your skidding? I disconnected the ABS on mine, pedal is rock solid and it stops better than my wife's van.
Also, the HVAC works better when in motion than when stopped. Heat is toasty while driving but gets cooler when stopped, a/c is cooler when driving but warms up with stopped. Its the auto hvac set up.
Does the blower slow down or just the temp changes? May be due to less flow through intake vents at idle then when in motion.
mac 'carts the baby around good' gyvr
