Ramsey
- Shreveport, LA
i would never do that...
mark would get jealous :laugh3:
BRIANHO13 said:Looks like I am going full width, found a guy selling a hp 44 (78 ford bronco) along with the 9" rear and all steering components and brakes for $350.
As long as its been done before I can do it.....If not, oh well I'm not skeerdXJ_ranger said:Nice - that is the deal that i got on mine
be warned though - that front end will only work with ford style radius arms...
there will be no cutting of brackets and re-welding...
Haleyes said:I'll take an hour.
Recent Redbird trip:
Man, I hate that tree. JIM.Haleyes said:I'll take an hour.
I have the same style front axle (big-azz RA mounts) and, if you're not narrowing it, those mounts would make a real nice platform to weld to.XJ_ranger said:Nice - that is the deal that i got on mine
kid4lyf said:I have the same style front axle (big-azz RA mounts) and, if you're not narrowing it, those mounts would make a real nice platform to weld to.
Just machine them down to a flat surface and weld whatever style mounts you want. (Standard rules apply for welding cast STEEL)
Ideal for LA setup.
Now if you're narrowing it, welcome to my hell.
Ramsey said:nice looking mj, a lot better than marks
:laugh3:
Lawn Cher' said:It rides more quietly too.
XJ_ranger said:good call - one other noteworthy mention -
SillyNeck on Pirate4x4 has an early bronco on 39.5's with the same front end we are talking about - instead of cutting the wedges off, or grinding them flat, he used the clamp part of the radius arm and welded his UCA pocket to what used to be the spring cup and welded his LCA pocket on where the radius arm used to exit off the back of the clamp...
i dont know what the radius arms are made of, but it might be easier to weld to thoes...
