Well in the old Jeep I ran the sliverstars in the 95. I decided I'd give these a try seen a lot of good things about the bulb's I purchased. Big thing was they weren't overly bright. I'm going to mess with them a little and try aiming them lower or getting a darker bulb sleeve for them before I I give up on them.
it's pretty damned impossible to make a LED replacement have the same light output as a halogen bulb, which i why LEDs in a halogen reflector housing will nearly always suck.
Projectors or full replacement housings with proper optics like trucklite or JW speaker.
There's a reason LED lights that don't suck cost $500.
it's not going to matter how far you point them down because the problem is scattered light far outside the cutoff, because the LED bulb puts light out in the wrong spot.
