altrocker1
- Iowa
Re: Re: Important
I thought about it, but it was 3 hours to go through a very secluded part of pa/ ny...I knew I had time to change it, so I did. I would royally f-ed if my injectors shut down in the Catskills but this way I still made it to work on time. I did think about buying another fresh battery since I need one for the mj...
Hell unless I had a bunch of stop/starts to make, or extended night driving to do I would have driven it where I needed to go for the day, and changed it at home that evening...
I thought about it, but it was 3 hours to go through a very secluded part of pa/ ny...I knew I had time to change it, so I did. I would royally f-ed if my injectors shut down in the Catskills.Hell unless I had a bunch of stop/starts to make, or extended night driving to do I would have driven it where I needed to go for the day, and changed it at home that evening...
There's a show called Punkin Chucking on Discovery. The hosts are usually the crew from Mythbusters, and the whole show is about different styles of pumpkin tossers. The air cannons usually throw the farthest. I believe the record is a mile, or right around that distance. IIRC it's on sometime around Thanksgiving time.
