- Southern Indiana
Nope. I'll just pull the new camper with the Jeep.
Also took the mj for its first cruise yesterday....definitely has a rear main leak
and the same wheel half cocked going straight that mine has.
pretty ricky also has a massive rear main leak. I keep washing off the downpipe so it doesn't catch fire. I'm putting it off until I swap the front axle.
I'm not from MO, but in Ohio you have to have receipts for material used to build it.
It's too bad you aren't closer to Wisconsin, just tell em you borrowed it from a friend up there and they basically can't do anything, iirc Wisco doesn't plate/reg trailers.
Under 3k GVW doesn't need a plate, if over then you do or if you want to pull in another state.
Anyone have an 8.8 and/or frD44HP carrier they want to get rid of for cheap?
