Important
Actually this is like the red headed step child car that is a pain to work on. Its a Chrysler Sebring but has the motor from Mitsubishi.
Oh dear.
I have no idea then. If it has 3 pins it's probably Hall though.
The HVAC in whitey is going to put me in the mental hospital...
The blower motor worked with all four settings but the blower was only blowing through the defrost.
I ran a new vac line inside to the blower controls. In the process of trying to trace the original vac line I had the entire dash torn apart.
I broke the original hvac control because i took it apart at the wrong plug and lost some parts.
I went and got another one from the junk yard.
I put that one in. It worked without having the rest of the dash in (or so I recall).
I put the dash back together then it was either blowing on high all the time (with the key off) or not working at all.
I thought that I might have screwed up the hvac that I got at the junk yard.
Today I got another one and nothing is working at all.
If I ground the wires that go to the fan, the blower works in each speed with it ground individually...but it works all the time even with the key off and the selector switch off.
I think there must me a wire that tells the hvac system to turn on and off and somehow its controlled through the ignition and the selector where all the vac lines plug in. The button that you push to turn the a/c on isn't lighting up either, which is one reason why I think that the whole control isn't working.
I have the dash torn apart again and nothing is working...unless I ground it out.
mac 'I've spent WAY too much time on this' gyvr
I had to go shovel a sidewalk for someone who is paying me (they requested I come as it is snowing and they are paying $20 each time). I took Sarah's suv (Nissan Roque AWD) and almost got it stuck. Jeep time now.
Mid 60's in my garage. Been wrenching, slowly. Drinking beer, slowly.
It's nice when you're doing stuff that doesn't need to be done to go to work tomorrow.
Fore 'last of my 5 day weekend' Wheeler
Sounds like its garage time thruout the mwc today. I'm trying to figure out why this car won't start. Think i'm just gonna start drinking instead since it won't run
Wonder what size the tires are, I need to get rid of the military tires on mine.
