Important
Hmmmm..... I'm wondering, would it be simpler to throw the shaft in a lathe and take the 1.25" off and machine a new pilot??
personally, the spacer made sense to me because the motor mounts on this little motor are about 1.25" behind where the factory 2.5L motor mount brackets sit...
that and if you blow a tranny, its plug and play. there are people giving away ba 10/5's for free out here
im also just a silly redneck though...i know i could ghettofab a spacer with a few jigsaw blades and a good drill if i ever had to.
Re: Re: Important
hint, check the you-pull for a mid to late 90s and early 00s Durango or Dakota. Check the sticker in the glovebox, if it says corp 8 or corp 8.25 axle and says rear limited slip, rip the carrier out and stuff it in your existing 8.25.
LSD 8.25s are really, really, really common in Dakotas (but are typically spanked and need new clutch packs) and fairly common in 8.25 equipped Durangos. Make sure it's an 8.25, they put the 9.25 in em too, just compare the diff cover shape.
I did my LSD swap in my MJ for the cost of gear lube and RTV because I took an XJ 8.25, stuffed the LSD from a Durango in it in the junkyard, bought the whole pile for $137, flipped the XJ axle on craigslist with my MJ's open diff carrier in it (yes, I reset the gears properly!) and put the LSD in my axle. The 8.25 is a side adjuster axle, so you don't even need any reshimming, and ring gear bolts can be reused safely once or twice if you use loctite on em. Make sure to keep each carrier bearing cup with the bearing it was broken-in with, though. I would have bought new ring gear bolts but I was on a shoestring budget at the time.
Didn't know Dakota's and Durango's has the 8.25 in them. Will add them to the list of vehicles to look for.
here is a pic of the back of the jeep bellhousing. this is pretty much what the spacer would look like. it could even be a little wider than the outline you see, there would be room for it IIRC
This is super handy info! I'll remember this for when I decide to get modding my 97. Of course, I've never checked to see if I've got a worn out LS in there already... But someday, I'd like to have LS and discs in the back of the 97.
Totally ideal build on the 97 for on-road use only: 4.6, 1" lift, stick with my current 245/75R15s or 245/70R16s, LS, discs in the back and beef sway bars. It wants to go fast.
Get me the maximum dimensions (the farthest points for height and width) and I'll see if it'll fit in one of our mills.
I thought dakota/durango were 8.75 axles?
mac 'oddly enough I brought up swapping them into xjs in the early 00s...6 lug killed that tho' gyvr
Durangos are 6x4.5 (odd) and dakotas are either the same or 5x4.5, I forget.
Remember that the 8.25 is only in around 10-20% of durangos and in a lot of dakotas (though the later builds got more and more 9.25s.) So it isn't guaranteed you will find a donor even with a dozen vehicles present.
And yeah I was surprised to see an 8.25 under there.
PS: many 3.9 v6 dakotas have ax15s functionally identical (same castings, same internals) to the one in a same year XJ aside from the bellhousing, shift tower casting, and shift lever. The transfer case bolt pattern is clocked the same. So if you roach an AX15, don't pay 3-400 that people ask for XJ ones, just choose your favorite donor at the JY. 3.9/5speed dakotas are incredibly common in the yards here, by virtue of being the basic/poverty spec model, though the 4cyl was available too... it is a jeep 4cyl in mid 90s and later, in front of an ax15. The bellhousing can be used to put an ax15 in a 2.5 jeep to replace the failure prone ax5 because of this.
Same goes for NV3550s too, and roughly the same year range. Pull the shifter boot and floor boot and compare the shift tower, if it is an nv3550 you will know.
Edit: and if you like to daydream, you can strap a 5.2 or 5.9 to an ax15 using the 3.9 bellhousing that comes from the v6/5spd dakota, though a 5.9 will probably nuke an ax15 if driven hard. If that doesn't give you ideas...
that's what is was, the 9.25...
jeepguy, i go to the local take a part from time to time, i'll let you know if i see an 8.25 with a limited slip...didn't know they were in the dodge trucks.
mac 'learned something new today...early' gyvr
tooo muchhh tech talk.....
BACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACONBACON
Rough day at work huh? Quoted for Bacon-y goodness!
Flexd'BACONBACONBACON'XJ
