Important
Expy. I like mine ALOT more than I did the van we used to have. Those back spark plugs are bad enough, without having to deal with a doghouse.
True, but I'd rather do plugs on a van. Pull out the interior engine cover and they're right there. Plus you can sit on the floor while you work :D
Actually, that was molly's old zj. I traded her my old cj7 for it a couple years ago. I changed a couple things on it from when she had it. It really is a small world.
Illianaxj- seeing your rig makes me miss my old zj so much. It was the same color also. I should have kept that one.
Ben, I always say I should have kept it too! I am so happy your kiddo liked it better than the CJ and you had a great time with it. Now we can drink away our sorrows together. Sniff. Cheers!
The 6.0 has got a bad name for fuel mileage, average Joe doesn't want one, making them cheaper.
The only problem with a Burb is garage space. I can park ky Hoe and Monte nose to tail, a burb would make it tight. I'm only 40' long.
Can't be worse than me.... 10 with the jeep hooked to it. My 1/2 ton averaged 13.... So I'm not actually doing that much worse
It's going to be sweet with the Napier sports tent come summertime... 8.1 powered hilton
Capacitor for the coil rail iirc. Probably fine if you stuff it on the dipstick stud you're looking at there.
looks like a knock sensor and that bolt there looks as likely a place as not to hang it :D
edit: Cap for the coil rail? Need to look that one up (maybe I learned something today after all).
No such thing as a knock sensor on '91 and newer, and a sheetmetal mounting tab like that would be completely ineffective for one (wouldn't put it past Chrysler... LOL) and I'm pretty sure he has a 00/01 so I think it's the coil pack capacitor.
The hole is to small to put it there.
Maybe! ;)
Yes 2000
I am certain ithas something to do with coil. Its in the same wire loom. I just dont want something dumb to keep this thing from starting. Want to put it in the correct location.
Canuteur valve?
I already did the C.V. delete on this one! :flipoff2:
Four more days of work this month. Next week, Sarah and I will be in Tuscaloosa (and in New Orleans for a few hours on Monday to visit a few people) for a mission trip. Going to stop in Nashville on the way home for dinner (and hopefully get a tour of at least the Ryman).
Also on that note, if someone has something needing to go south or back from the south, if it is small enough, we should have room in the Roque.
