Important
Looks good, but what's up with the MT/R's on the rear, the tread looks "finer" than the fronts.
Nice work Gene...and it doesn't say "free candy"
mac 'never been able to afford the new body style' gyvr
Had a pretty good first week:
New NAPA Legend Battery
Fixed battery lugs
Broken factory roof rack removed
Dents somewhat taken out of the roof
Repainted the roof part where the rack was ripped out
New power steering hose
Factory air box installed
Rear hatch struts
Turn down on the semi broken exhaust.
Also a pretty good weekend:
New front motor mount... Old was in 3 pieces!
Installed a hood safety latch from pick a part
Soldered on a new aux. fan connector from pick a part
Installed Pats roof gutter protection system
Rotated tires
License plate light
Interior dome light
Third brake light
Battery hold down from the pick a part
Sitting next to Pats
Close view of the tree guards
Sampling the expedition rig setup
And another
Big"glad to be back"Hank
The Expo rig setup looks badass Gene!
Flexd'Zombie apocalypse ready and I want roof sliders'XJ
i like those roof sliders, kinda want to ditch my basket on top
Looks good Gene, I like the expo theme. Just don't go all Expedition Portal on us :D
The plethora of cheap(er) XJs on the classifieds is making me want to save pennies for another rig, and I'd like to go the 'expo' direction with one as well (even though everyone knows you have to have a FJ40 or 4Runner to be a 'true' expo rig :D)
You are dead to me.
I literally LOL'ed at this.
http://www.naxja.org/forum/showthread.php?t=984963&highlight=toys
here ya go Nate. This was from a few years back, before they were repainted and cleaned up.
The carnage and destruction that could have been wrought with one of those is unimaginable
Wish I had the cash to buy one of those HEMMTs! They are truly badass. My 5 ton should do ok once I finish putting it back together though. I get horrible gas mileage but will still be dollars ahead on a diesel pickup + trailer for several years since I only have about 3500 into the rig. Might be 4k including the steel I had to buy to build loading ramps.
The budget for my Uhaul toterhome conversion is about that. We were going to buy just a trailer, but that still left me borrowing a 1/2 ton tow rig. Uhaul (Mehaul?) is not much more and solves all of those problems. And I'll have a nice dry, heated space to sleep/work on stuff at the campground.
Retreads are in the rear. Hopefully everything that says good year will be gone soon! I'm really liking the idea of Firestone Destination M/T's.
Josh had some, they worked well offroad and in the rocks, weren't horrible on the street. I drove it from CO to OH anyway on those tires.
I can see pats hand prints all over the side of that tree guard Gene! :D
That's the kind of friend that Pat is. I take the time to lay the rack down on a 30 degree gravel driveway with a 20 MPH crosswind. Then spray bomb it with a cheap rattle can. Pat decides to jack his leg on a fourway he left hooked on a lug nut and fingerprints my awesome paint job!
Big "thanks to pat for using his shop"Hank
Thanks to all for sharing your brake info...Heres what I'm gonna try.Installing a brake booster and pedal assy from a 98 XJ.This will allow me to use a Master cylinder from a 1999 Dodge Ram.
Nick
Nick
have you tried gutting the proportioning valve?
a side note, I hate recapping PCB's. it's so PITA.
ugh. agreed x1000. I hate getting the old cap out and cleaning the pads up more than installing the new one.
Nope,I havn't ruled anything out..I'll add your idea to the list.
Nick
Mine is ffuuuuuuuuuu
It's going bye bye next month when I get back to working on the Jeep. Probably going to do a wilwod jobby like this:
http://www.summitracing.com/parts/WIL-260-11179/?rtype=10
I cheat, I use my desoldering iron, heat the pad up from the back and stick the lead from the new one into the pad and up into the desoldering iron tip. Saves all that tedious work cleaning up the holes and making the new ones go in proper. It's still PITA.
I just got back from winding the village clock. Man, I must be getting old, that shit had me winded and my nuts were sweaty. Of course my little cousin came along, so I was working faster than my normal winding pace because they were on a schedule.
87 "clock winder" manche
When I can, I clip the part off and then use heat and a quick blast of compressed air (if I've no idea where the compressor is, as usual, that means I blow hard on it myself, make sure to put the iron on the OTHER side of the board if using this method!) to blow what's left of the lead and most of the solder out of the hole. Then I clean up with solder wick and install the new part. Caps are a pain though because there usually isn't space under them to get the clippers in.
just jerk the caps off with a pair of pliers. The leads will pull right out of most of them, leaves you with a PCB that just has a bunch of leads sticking out. You'll still have to clip them, because most of the time they have flat bits in the cap.
If it were anything more than a video card, or something that I REALLY cared about and wanted to be clean I would use a solder pump and get the holes opened up and clean, but to be honest, this was on a Geforce 6200 video card, so it's not the end of the world if it looks a little nasty around the caps. A dab of flux and the old solder sticks to the caps just fine and voila, done.
Last time I did that it was on a shitty quality PCB and I ripped the pads out. It was a multilayer board, so no repairs were economical enough... into the trash it went! Been reluctant to use that method again since then.
yeah I could see that happening.
if you heat up the lead before jerking them out it softens the plastic in the cap, then it doesn't happen.
Like I said, I wouldn't do it to anything that was expensive or important, but fixing a junk video card IDGAF.
