- Michigan
well, the jeep is almost back together after 3 days of thrashing. :repair:
what i got now is an 89 renix block, with a 94 HO head and a 96 intake. :farmer:
i made it all jive using some creative engineering, thank god i have the capacity of abstract thought.
the problem now is i have the serpentine setup that of a 97 and up. it seems that 89-ish renix blocks had an extra tab on the timing cover, the 97 and newer doesnt. thus, when i route the belt 97 and up style, the belt is intercepted by the extra tab. soooo im thinking of hacking that little extra tab off so the serpantine belt can go onto the crank pulley correctly. any thoughts?
I think if you can make that combo work together, you can figure out what to do to make your belt work
I like your attitude, glad we met at WF and if you ever need anything, get ahold of me.
You're a good kid under all that moonshine
dan
