Big Red
- Roscoe, IL 61073
Jes said:I have a 10LB. tank and while I like it and it fills my tires quickly, it is expensive. I probably go through 6 or 7 tanks a year and at about $15 a fill up that ain't cheap. Also, when you run out and only have 3 of your tires filled it can be a PITA.
Do you wheel that much Jes or do you have a leak???? I know you wheel a lot but you need 6-7 tank fill ups a year. Do you fill eveyone up in your group? :laugh3:
I jus got a 20 lbs tank and should have it together for the Hollister run tomorrow.
Troy
