philip_g
- back in CO
I think the previous thread got lost in the server hiccup.
here's the deal: the jeep wants to idle at 3000 RPM.
to make it driveable I've blocked off the little triangular passage through the throttle body with my costco card :gee: if I remove or unblock that passage, it shoots right up to about 3k RPM.
what I've done:
tried 4 now IAC motors, one of which is brand new
tested the intake charge temp sensor, IIRC it ran about 5k ohms on a 50 degree day, sounds about right
new TPS, adjusted as low as it'll go
found and fixed a few small vac leaks, hoses leaking etc. tightened the manifold bolts I can get to, sprayed carb cleaner all around the manifold and don't think it's leaking or not enough to cause that much of a problem.
sprayed all the other vac lines I can find.
cleaned the grounds, ran a new cable from the (-) terminal to the passenger side of the block, oddly enough I used engine degreaser to clean the connection and must not have cleaned it all off because it wouldn't start after, cleaned some more and it's fine.
flushed the heater core, it didn't help the idle but at least I'm warm now :clap:
I think that's about it. I can't think of anything else but dynamite.
what I've done:
