..Ripper, I say again,.."all XJ's erespective of model years 1984-2000 have the same engine compartment + exterior dimensions-For example if you're wanting to install the V-8 into say a 1984 model year XJ you merely take out your favorite cutting tool and cut out the topmost front cross-member and voila there is the additional length you need without haveing to modify the firewall-Takes all of about fifteen minutes-(sorry I don't have any pics anymore) -Also do a search in the
archives under my name for some additional information and suggestions-HTH
bxj
Old engine (very underpowered ) was,blown and burned out (..free..)1984 XJ 2.8 liter engine-rebuilt at least two times before I found the Chevy V-8 5.7 liter as a cost-efficent and easy option,...
Here is some details about my heep...
1995 Chevrolet 350 V-8 LT1 5.7 liter (carbureted ) light-weigh aluminum heads and simple( non-fuel injected )- ($800.00 crate engine)+ Chev-Delco 200 amp alternator + Be Cool aluminum radiator ($500.00 )
700R-4 trans($200.00) with ye ole Ford Bronco Dana 20 transfer case($200.00) with 1996 Ford 8.8 rear axle($500.00)
Advanced Adapter(Paso Robles, Ca) motor mounts and Chev 700R-4 transmission to Ford Dana 20 transfer case adapter-Wild Horse's(Stockton, Ca) Ford Bronco Dana 20 Extreme Duty 32-spline output kit-Rusty's 3-inch lift kit also various inexpensive miscellaneous local boneyard parts-Older model Chevy 1973 exhaust manifold, newer/used 1994 engine hood+spring fittings,1996 ZJ Jeep Grand Cherokee brake booster and proportioning spring-
