OK, If you guys are done discouraging him, here is how it should pan out. You will need the 2.8L bell housing out of an 85 or 86 XJ. It will bolt to the new engine. You need a fly wheel out of the camaro, or out of the XJ and remove the counterbalance weight from it. Stock 2.8 XJ clutch with the matching slave cylinder. XJ 2.8L motor mounts will work along with 2.8 radiator, however it would be better to get a 2 row radiator for this application. Use your wiring from the fuel injection for the engine. Your intake will have to be drilled and tapped for the analogue temp sending unit for gauge. Also you will have to do a little plumping for the oil press sending unit and have two sending units on one port, one for the ECM and one for the gauges. Replace the in tank sending unit and pump with one out of an 87 and up XJ with 4.0 Throttle linkage cable out of an S10 will probably work too.
