Thought I'd update this. BTW, my steering is finally working perfectly.
After the last post, I sent my steering box and a spare pump to Lee Mfg to be rebuilt. The box was toast, the sector shaft was cracked and the bore was oversized. So, it was likely that the fluid was blowing past the seals in the box to some degree. I had to virtually get a complete box from Tommy Lee, upping the cost and pushing me closer to what it would be for full hydro, but oh well, I was too far into it at this point and needed to get it done.
Along with the new box and pump, I added a remote resevoir and a filter. Tommy Lee has a nice resevoir and filter setup that you have a choice of using either slip fittings or AN fittings. I went with slip fittings for simplicity and ease of spare parts down the road. The pump was built to accomodate the large 5/8" hose that comes from the resevoir, a slip fitting on both. The filter also uses slip fittings and installs in line, so it went between the cooler and the resevoir. A very nice, and very simple, setup. I also went to AN 6 size hoses going to the ram. So, evertything in the system, including all the hoses, was brand new except the ram.
I got everything installed and did a run to JV. It worked so much better than it did before, but it wasn't perfect. When it worked it worked pretty good, but occasionally it would still get harder to steer when worked hard and the pump would whine sometimes.
When I got back I replaced the 1 5/8" Rocklogic ram with a 1 3/4" PSC ram. I still wondered about the pump, and I ws so damn close to the expense of just going to full hydro, but I figured I had replaced everything except the ram, so I was going to do a new ram before changing anything else.
The ram must have been bad, because now it works. And, with the 4.5" pulley I'm using and the larger 1 3/4" ram the steering kicks ass. Quick and powerful.
Finally!!!!!!
