themud
- Scottsdale AZ
Just finished setting up and installing my box and ram setup and noticed its a bit laggy at idle if I give it a couple hundred rpm or so it does much better so the question is do I drill out the piston like west texas offroad says or do I put a psc 4.5" pulley?
It seems to do just fine at 45 or so in fact its down right darty(I need to get used to the power there and my steeringg no longer wanders) so that helps as well.. Just not sure if I want to spend the 50 bucks for the pulley?? I have no problems dropping the coin for it but if drilling out the piston does the same thing itll be cheaper but I don't need anymore assist at high speed which is why Im leaning towards the pulley??
thanks for the help.
themud
themud
