HP44 and Dana 60 4 sale
Status
Not open for further replies.
bigjeepman
New Albany, IN
i bought a HP44 and a Dana 60 from indyjeepnut in November and had gears installed(4.88s) front and rear. I also had a spool installed in the rear. BrianHO13 welded the brackets on the front axle(I still need to change one) and installed the front gears. i had a race car builder install the rear gears and spool. The brackets are the rubicon express axle bracket kit. Brian did a hell of a job installing
I have all new Brakes, ball joints, Calipers, rotors, drums, Shoes, wheel cylinders, and spring kit(for shoes).
Decided not to run full widths after all. I want to run stock sizes axles and no bigger than 35's on my jeep.
I have well over $1700 in parts and labor to get hese built.
I am asking $1500, I will take less but I will not finish installing the brakes, etc. Pm me for more details.
Will trade for XJ 44 stock or otherwise built similiar width axles. PM me if you have something else you want to trade. I can take pics this weekend. I am planning on finishing all of the install for the brakes and bearings and hubs this weekend.
i am traveling to the Knoxville the weekend of March 1st so I could bring them along if that is necessary. I was going to come to winterfest but plans change.
PM me with offers or otherwise
kst8engineer, your pms were full
my pm to you is below
I do still have the rear carrier if you want to go open on the rear. The rear just needs to be installed and when installing you just have to pull the springs apart by 1/2 inch on each side. No ill effects from doing this. The rear shock mounts need to be welded on because where I want them may be different from where you want them. I need to finish installing the rear brakes and wheel bearings. Also this axle is the full floater.
The front has lockout hubs and the mini spool is still in a box. I need to turn one bracket but was waiting to do that until I started to install the axle so I knew exactly where it needed to be. I just got done installing all the brakes and brand new bearings up front as well as brand new superwinch hubs. I would recommend getting warns whenever you can if you decide to purchase these axles.
I bought the gears and everything from porc and it came with a lifetime warranty. I would have to call them and verify that that warranty can be switched over to another user.
I changed my mind when I saw my cousin run some of the trails around our house with his full-width cherokee. It hampered him in getting through a lot of our trails we have now because it was wider. He would fit but I didn't like how tight it was. I loved the looked under a jeep but right not it was not for me. Plus I pretty much decided to stick with 33's fornow and may go bigger later, but I have been eyeing a CJ for a full width chevy 60/14 combo here lately making the cherokee a fun driver for the weekends and the occasional trip to work/riding(atv)/ camping jaunts
Let me know what youo decide to do.
Thanks,
AXLES ARE SOLD TO SHORTXJDOUG
Status
