HP30 vs. LP30
barillms
What's the advantage of the high pinion Dana 30 vs. the newer style low pinion Dana 30? Besides clearance? Can non disco 297x shafts be used in a newer low pinion Dana 30 that came with disco shaft?
ground clearance and decreased front driveshaft angles. a non-disco shaft will fit in a disco housing, but the shift mechanism needs to be modified or removed and a new oil seal needs to be installed since the non-disco shaft has a smaller O.D. than the disco shaft does.
Front Axles
Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear ( used 1984-99 ) -some axles through 1991 are vacuum disconnect. 1992+ are non-disconnect. 1989-95 with ABS have 5-297x u-joints, all 1995+ have 5-297x u-joints, all others have 5-260x u-joints.
Dana 30 low pinion - standard cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear, 5-297x u-joints non-disconnect - used 2000-01.
