89eliminator
- Delphi, IN
HP Dana 30 out of a 91 XJ
4.10 spicer gears
lock right locker
chromo shafts w/ spicer joint
artec truss, still has 4 factory location control arm mounts
comes with steering which over the knuckle with brand new tie rod ends. tie rod does have a bend to it (high clearance
trackbar mounted over the axle. trackbar, frame mount, and custom crossbrace included
4 month old timken unit bearings
ballistic fab diff cover
adjustable lower bumpstop pads
$800obo
MJ D44
4.10 spicer gears
detroit locker
alloy shafts
liberty disc brake swap
rockcrusher cover
setup for 4 link using a genright truss. the SUA and SOA leaf perches are still on the axle. would just need to weld on shock mounts to run it with leaf springs
$1000obo
these axles are proven to work with 35s. anything that has broken has been replaced with better parts. located in southeast WI
4.10 spicer gears
lock right locker
$800obo
MJ D44
4.10 spicer gears
detroit locker
alloy shafts
rockcrusher cover
$1000obo
