John(XJ)Jeep
- Guelph, Ontario, Canada
Sarge said:It's NOT beating the back pressure. It's finally hit the spot where the scavenging is working the best. It also has to do with the intake and the cam.
Well technically I didn't word it properly as I just found out but what I said is what scavenging is. Look, I don't want to argue with you people I just don't agree with you guys are saying. :wave: It just doesn't make sense I guess to me because your pupose of exhaust involves low end and I'm looking for mid to high end power.
I found out what scavenging is exactly and I can tell that I don't want it. Seeing that the torque gets moved to the low end that's where not the horsepower should be in track racing or I should say in that area of performance. In four wheeling you want low end power low speed, low RPM in such. When you pound the pavement you spend most of the time at high speed and high RPM so in turn I want as open an exhaust as possible without being too extreme in my position.
"For virtually all high performance purposes, backpressure in an exhaust system increases engine-pumping losses and decreases available engine power. It is true that some engines are mechanically tuned to "X" amount of backpressure and can show a loss of low-end torque when that backpressure is reduced. It is also true that the same engine that lost low-end torque with reduced back-pressure can be mechanically re-tuned to show an increase of low-end torque with the same reduction of back-pressure. More importantly, maximum mid-to-high RPM power will be achieved with the lowest possible backpressure."
This is what I beleive in
