i just got done narrowing a 79 f250 44 to wagoneer lenght. i used the crane inner and outer high steer knuckles and i wanted to know whats the best outer setup to use to get the 5 on 5.5 bolt pattern. can i still use the outer waggy shafts?
What's the advantage to this rather than the stock hp44 stuff?
19 spline outer stub shafts? Is there anyway around this to get more splines for little $? Are the outer stub dana 44 shafts weaker, as strong, or stronger than the dana 30 stub shafts?
