Ary'01XJ said:
Well, I've had them for about 4-6 months and they're well broken in. In fact, they're beginning to take on a "w" shape.
As for the shackles, I'm running a 1" pro-comp shackle and it sits just slightly angled back past vertical. Could that be my problem?? Thanks guys
Ary
P.S. With the springs and shackle I think I'm getting 5" of lift, but I don't have any real way to measure since I no longer have flares.
Ed and some of the guys have made some very good comments, this is an informative thread. Overall, it is pretty simple. You need to loosen up the rear and stiffen up the front. We've found that the ZJ front coils just work the best, and they have the stiffest spring rate available.
In the rear, make sure the shackle bolts can be turned with an end wrench, snug but not tight. They can be run like this all the time, not just on the trail, as there's no force to make them loosen up. Mine have been that way for years. The rear spring shackle has to be longer than stock, to allow the spring to travel freely. The leaf spring has to be free from friction, so make sure it's clean between the leaves, or take the spring apart and put full length liners between each leaf. I've also been running full length liners for many years, and it helps. The loose bolts and the liners mean less friction, but the spring rate and carrying capacity remain the same. Also, be sure the spring clamps are loose, not pressing the leaves together to create friction. You can also open the clamps up, or remove the bolt, depending on what type of clamps you have. Be careful when running open clamps that you don't flare the leaves too much under full droop, it can cause a problem when climbing, and reduce stability similar to what happens with a Revolver shackle. I ran open clamps for a long time, but when I put the Tera60 in the rear it is so heavy that it flared my springs way too much when drooped and going up hill, so I put the clamps back on the rear part of the springs.
Regarding rear spring rates, it's better to have a flatter spring if you want the rear to flex. I use a couple inches of block and a flatter spring to get the flex and lift I want, then a traction bar to eliminate spring wrap. The flatter spring both compresses and droops better than a spring with more arch, and the shackle is moving forward rather than backward through most of the springs action (it's already back when sitting still with a flat spring).
Here's a few pics of mine to see what's possible. I hope my friend doesn't mind me using him for comparison....this was taken two weeks ago on BOTW.
http://www.fototime.com/1600B4AEA5AD92D/standard.jpg
http://www.fototime.com/BDE8F8D9CF28BC3/standard.jpg
Close to the same line, but more balance between the front and the rear. Here's another:
http://www.fototime.com/83F2C47D36D386B/standard.jpg
Here's a couple from a few years ago:
http://www.fototime.com/F357B3CEB75AC2D/standard.jpg
http://www.fototime.com/D3319C2C4983094/standard.jpg
Keep working with it, you can get it balanced.
