- Lakeside, CA
feel free.
case deflection in the D30 is the biggest problem. its why I have a broken ARB sitting on my bench
obviously you should not go over the maximum bearing pre-load, no need to damage the case, or cause excessive bearing wear. but plenty of gear installers don't want to get out a case spreader to get the maximum pre-load.
It's hard to over preload carrier bearings. If you can pull/install the carrier without a spreader then adding .005 to each side and install it. You can still get a D30 carrier in without the case spreader. That's what heavy dead blows are for.
http://www.ringpinion.com/technical...s//Four_Critical_Ring_and_Pinion_Settings.inc
As for price, it will depend on the area. I would say anything around $300/axle give or take is probably reasonable, not including parts.
