- WA state
That was before, I've seen his XJ.. I believe there is an older thread in the sierra chapter on his xj. That shows stages.his avatar shows different...
I'm not sure on the east coast, but in cali I don't think you can. If you take your rig to your local landfill, they should weigh it for you and give you a sticker with said weight on it, for free 99Question: can you pull into any truck weigh station to have it weighed??
Because after 6 other 4wd xj's I've owned the 2wd is much smoother for go fast in the dunes boss. With speed you don't need 4wd, especially if your locked. I've gone through shallow rivers, rock beds, etc. And in the event I get stuck (which I have never before) i have a winch to pull me out. That's why.
exactly! my buddies 4wd jeep got stuck in a witches eye. His vehicle stayed there for two days lol.I remember the days!! Back in the '80's we started running our 4WD's in 2WD in the dunes. Everyone thought we were nuts. There's a learning curve that took a couple years to get comfortable with. Only got stuck once in a rat hole. But for casual wheeling and dunes it works! Our group had fairly well built CJ's with V8's... mostly Chevy 350's built. But others had stock Mopar V8's and did pretty darn good. We ran paddles (Sand Tires Unlimited) on special 12" wide aluminum wheels on the rear and small grooved tires in the front. Rear tires were regrooved: every other paddle removed as was excess rubber. The tire & wheel could be picked up with 2 fingers. Unsprung weight was the key as was lightening rotating mass. Opened up a whole new world of running dunes in a Jeep. In our case, we kept our front diff so we could still do crawling.
Edit: forgot to mention: Jeep was a CJ-2A and weighed in at 1900 lbs. with a Chev. 350 / TH350 trans / T-18 T/C and 44 diffs. Don't even want to know what my '94 XJ weighs.... mostly exploring now.
why is your left front so heavy?
