Wolfpackjeeper: When it comes to making power, dyno numbers mean way more than ET's. I however, am looking for both.
BBeach: You've never heard of
MARSHALL engines??? I thought they were pretty well known. But in case you can't READ, I mentioned previously in THIS THREAD that I spoke with a tech person for Marshall and verified that their motors put out the same amount of power as stock... because they ARE stock... suprise suprise. . What an arrogant asshole thing to say. So I'm assuming since you don't agree with my exhaust set up in the performance department (I'm not even gunna mention the environmental department) that you either think that:
A. Cats HELP scavenge or
B. My exhaust set-up (a straight-through design) is losing power because it doesn't have enough backpressure (that backpressure is a good thing)
Both of which is just plain false. Obviously, YOU are the one who needs to look up scavenging...
"Mufflers -- Two Golden Rules To Avoid Power Loss". "...To achieve a zero-loss muffled high-performance race system we need to work with the two key exhaust system factors in total isolation from each other. These two factors are: the pressure wave tuning from length/diameter selection, and minimizing backpressure by selecting mufflers of suitable flow capacity for the application..."
Holy shit did I just hear "MINIMIZING BACKPRESSURE"!? And that was just the first google hit I came across... oh, and
here's the link in case you feel like getting educated :wave: ... dickhead.
Seanyb505: I won't say "here's a dyno sheet and it PROVES that a straight-through exhaust design due to its low back-pressure makes more power than a system with more backpressure". I don't have the means to do the test correctly. I don't have the time, or money, or will. But I will say "here's a dyno sheet with much higher numbers than a stock dyno sheet and this is the kind of exhaust set-up I'm runnin... you can take whatever you want from it".
Or you (in general, not sean) can just be an ignorant tool and make up excuses for why the results might be a little flawed and flame someone who isn't able to spend a weekend with a dyno to "prove" something.
