Free flowing exhausts Move around the powerband. And a 2.25in free flowing exhaust is going to make more power on a cherokee than a 3.25 in exhaust, due to flow velocity dropping off. Every time this debate comes up people start comparing if a cat is restrictive, then it moves to how big of an exhaust, then it moves somewhere else. Length, diameter, smoothness, obstructions all matter. Making one dyno run is not going to settle or refute anything. It will just add one datum point to be considered.
2 settle this would require the following pulls:
3 run bone stock
3 run stock with removed cat
3 run larger diameter with cat
3 run larger diameter with removed cat
this is the minimum number needed and more would probably be better, and considering dyno runs in Raleigh cost 75 bucks for a 3 pull average, I will not be dropping the money to do it. I like the exhaust on my stroker, and I like the exhaust on my stocker, both are very quite and serve me well.
