XJLI
- Long Island, NY
Cool, thanks for the info dude. Anything I pick up will have over 100k but it's an expensive truck to begin with so hopefully the PO kept it maintained
T-case yes, power steering fluid, no.The power steering and tcase fluids are WJ specific, for the steering it is a mopar fluid because it has a connected hydraulic cooling fan. The tcase fluid is mopar only also, because of the viscous coupling in the 247 case.
Several aftermarket power steering fluids meet MS5931 specs. Its not special.Mopar®P/N 04883077 Hydraulic fluid / Power steering fluid (MS5931)
MS5931 IS THE ONLY FLUID THAT CAN BE USED FOR THE POWER STEERING SYSTEM. NO EXCEPTIONS!
Which is significantly different from a viscous coupling.And about the tcase, fair enough, it is listed as a "gerotor coupling"-
Correct. The NP247 is the only Jeep transfer case that I know of that needs a special fluid.Only the NP247 has Mopar specific fluid. The 242 is normal, right?
Not dificult but time consuming and you need the AC drained and refilled.-HVAC blend doors and heater core leaking are big problems. Both are about $100 in parts, but require removing the entire dash. I want to say it took me about 10 hours to do taking my time. Expect to pay ~$1k to have a shop do it.
There are a few decent projector lights available for the WJ. I do recommend protecting them with some form of thick vinyl like Lamin-X to name one. Protects from rocks as well as oxidization.-Headlights oxidize. Quick job with an off the shelf polish kit, or under $100 for new replacements.
My mother's hit 198k last week.I own a 99 4.7 that I got from my girlfriends parents. They babied it, and its in very good condition for how old and how many miles it has. At ~147k its got problems, but I am slowly fixing things. Heater core and blend doors failed, that was a fun weekend.
From the reading I have done, most seem to attribute the DW to having the control arms closer to the center of the axle than other axles.In a conversation with Blaine, he'd said the WJs & JKs are prone to DW due to the full crossover steering design. Given what I know about DW (vibrations build on each other until amplitude makes you crap yourself) I'll say this sounds feasible... anyone smarter and or more educated than me want to chime in?
look for dual climate control. Those are the doors that fail. Heated seats can also be an issue. 96K is low mileage and it should last you another few years.
The price seems high to me. $4K flat is about where it should be.
It has the dual climate control. Is it at a dealer or private party?
Any 10+ year old vehicle is hare to find with under 100K on them. They are out there.
All in all it is a decent price.
I have an 04 SE and love it. It doesn't have the blend door issues or seat heater problems as well.
My only issues since it bought it in 04 have been,
water pump replaced at 26K under warranty
rattling cat that I caused by hitting a rock in JV, replaced under warranty as well.
cracked t case, again caused at JV. I replaced that as it was totally my fault.
TRS went bad in the trans at 95K. $300 fix in the driveway to replace it.
The biggest thing was almost all the wires in the doors broke and the main power wire shorted out against the body at freaked out the BCM. Once I repaired all the wires everything went right back to normal. I gave it to my son last year for his 16th birthday and he daily drives it with 150K on it.
