How do i know what t-case will work?
fyfebrij
chesterland Ohio
Can anyone tell me if the t-case off of 93 zj will fit a 95 zj? Both have the 5.2's. The 95 also has limited slip rear end if that makes a difference (i dont' think it does)
If they had the same transmission and t-case then yes it should fit.
If they did not...then you will need to compare the input shaft length on both t-cases. The spline count should be the same for both at 23 splines.
even if they are different you can swap the input gear from your old one to the new one, as long as it's not damaged.
Moving to Other Tech.
