Part I: I was working on my 95 Sport the other day and noticed a rubber hose dangling at the bottom of the engine compartment. I traced it back and found the other end connected to the top of the transmission (no hose clamp there, just slid on nipple). The loose end has a section of angled metal tubing and a mounting bracket with a rather large mounting hole in it. Can someone tell me what this hose is for (I'm assuming it's for drainage/air) and where this loose end mounts? I couldn't find where it would go.
Part II: While underneath my XJ, I noticed tubing from the front differential running to the engine compartment. It had a big hole in it from where it rubbed against the front driveshaft. Is this for drainage? Or is it a vacuum hose of some sort? Would a hole in the tubing have caused damage to the front differential at all, or should I change the fluid because of this?
Thanks for all your help!!!
Matt
Matt
