How do you guys go about opening your hood when they break and wont open? The drivers side will open but the passenger side wont, any ideas on how to open it?
There's a way to reach up from underneath with a socket and a long extension to unbolt the loop that hood latch attaches to. There's a good shot of it on from a few years ago.
Mine does the same thing. Haven't fixed it yet but what i do is lift up on the drivers side that opened and rear in and pull on the rod to get the other side to pop.
If you pull the headlight supposedly you can get to the two screws (one horizontal, one vertical) that hold the other end of the latch in place.
I usually reach up from underneath through the path of the fans and belts to grab the latch rod though. Easier if your e-fan and/or shroud are missing.
