Hood vents preparing for spring
0313 said:
Tried the magnet thing, too bad the vents are aluminum and well they arent very magnetic.
LeBarons had aluminium vents? Every set I've ever pulled has been plastic.
I used Z-34 vents. No problems with water. JIM.
Gojeep said:
Went to the main page on that site just now and Nortons caught a Trojen virus from it!
Not good. Even worse is that my Norton didn't say a thing, maybe you got the last one.
What is the name of the trojan?
As far as vents go, I have the scoops (one per car) off of a 300ZX. I'll be mounting them reversed when I finally decide where to put them.
Gojeep said:
Have you got a shot of what it looks like from underneath?
I'll try to get one today. JIM.
Screw vents... I just cut some holes in the hood with a hole saw..... 3 core radiator and I run at 190 all day long. Never had any problem with water, but then we don't get ALL that much snow melting here.
DO NOT USE MAGNETS... I used em on a drive down to Uwharrie last year and ran through a bit of rain.... 2 days later when I lifetd the magnets I rad light surface rust under it. It buffed out ok but I wouldnt recommend it except for a short time maybe. Just my $.02
Plus they're just plain ghetto fabulous....
Dumb Question Alert!!! If you're going to cut up a hood, why not just cut out the catch pans stamped into the Lebaron Hood (and all other vent equipped Turbo K cars) and weld them to your Jeep's hood?
Really, I thought the ones I bought FROM YOU were aluminum.
Im a dumbass then. I can admit that. They are made of different plastic then. Either way, the magnet wont stick to them.
I actually like that look. Creative.
Actually i really like those vents.. pricy sure but i think ill get some! sweeet!! much nicer then the others i have seen.. go for it!
Aaron
I didn't cut through the bracing, but I did drill some drain holes in them. JIM.
i just got a set of the lebaron vents today, they are filthy, are they dishwasher safe? some plastic melts
