I'm with the guy up top, it is an ingenious idea, that is has not been done before, and cable clamps are used on cables that can have more weight than a cherokee applied to it (assuming the correct size of cable is used) but cable clamps are designed to hold cable together in the opposite direction thought the hole, not the way he has them therefore the threads in the nuts and the threads on the clamp are the only thing that is holding it together, I would suggest you weld them to the bumper for safety.. but why not do what the other dude said, simpley make new mounts for the bumper that extend through the bumper and drill and put shackles in the ends, cut slots in the bumper, slip it on and weld both front and rear of the bumper and you know have super strong tow points since they are pulling directly on the frame and not the bumper (which can casue the bumper to bend.) Plus I have found it makes fitment of the bumper easier, cause you can get that bumper nice and close to the body.
