Mudderoy
- Katy, Texas
Looks like google sketchup. if its not, everything ive seen so far can be done on sketchup, and its free!!!!
Cool, I'll go have a look. Thanks.
Right now the entire tire carrier assembly is balanced on a single 2" tube. You are trying to figure out how to jam wedges in here and there to prevent side-to-side motion of the 100 pounds or so that's stuck in the center of your receiver hitch.
Stand upright with your legs and feet tightly together. Make sure you're holding a large weight in your hands and have someone push you sideways. Not too stable, right? Now, spread your legs shoulder-width and have them push you again - much more stable.
What I recommended is similar - support all the weight off the main support as you already have. The Detours bolt-on D-ring fittings gave me the inspiration; instead of using them as a D-ring mount though, use them (or a similar construction) to make an extra "leg" that will help support the tire from rocking side-to-side.
Jim www.yuccaman.com
im not positive on what im gona do for the light. im debating mounting mine on the bumper or the wheel. at the moment it's ziptied to the wheel so it's at least visible.
but as for the wedges it shouldnt be able to rock as long as the wedges are in so idk have to see haha
