Demonoid369
- Salem, OR
So I know there are multiple different way to go doorless(unbolt door, cut hinge, cut hinge while door is still on, knock hinge pin out and don't unbolt and cut hinge, etc..) my concern is with the last one. It's for the passenger side door and I know that side the pin is on upside down. I want to try this way since it seems to take the least amount of work ish while not have to re-align the door back on. Question is this: do you knock top pin out first or the bottom? And what methods works the best at knocking the pin out without destroying it? And when swapping the pin back on to the top hinge, does it fit tightly or should I tack it? (Reason being is I have all the tools at my apartment but the welder so if it would need to be tacked on to stay, ill drive over to my parents house where my welder is)
Also this is for a early style hinge, not the later model
