jeepman121
- Ohio
Now before I go and issue the problem, thhere are a few others I need to mention to help you diagnose...I need a battery and my belt squeels when I run too many devices, and upon warm up the volts read above 14 occasionally when at an idle my oil pressure guage will bounce but if i turn off my heater or another device it usually quits...but when the motor is really cold the oil pressure guage goes really high if i go under alot of throttle. I floored it to about 60 mph and the needle was almost all the way burried! I did add lucas oil on my last oil change so I'm thinking maybe its too thick upon warm up... But I dont know for sure thats why 'm here...its a 95 XJ with an auto. thanks, Josh
