76 Fuel Pump Resistor Bypass Relay Circuit. An open or shorted condition detected in the ballast resistor bypass circuit. The Balast resistor is by-passed during crank.... A code 72 could be a possible result of the cause of code 42......
42 ASD relay control circuit. An open or shorted condition detected in the auto shut down relay circuit.
If the relay is not operating, it knows it. It has a monitor for the output and pops a code if that output voltage is too low.
A shorted fuel injector or O2 sensor heater will cause a 42, for example. Too much current draw from the short results in low voltage on the circuit... pop! a 42.
A missing ASD relay during key-on or cranking will pop a 42 also.
54 (no sync during crank) is definitely your your no start. The PCM is not getting a sync signal from the cam sensor ( herein referred to as CMP) it will turn off the ASD relay during crank if there is no CMP. This effectively shuts off the coil, the fuel injectors, the fuel pump relay and the O2 heater. (alternator too, for that matter) ...well, everything the ASD controls, that is.
I saw that you direct-grounded the sync sensor 'ground' wire. That is not supposed to be direct grounded to chassis/block ground. That is what is called a sensor ground, which is fed through the PCM. It is such that the electrical noise associated with chassis grounds are filtered from sensor circuits.
You are causing no harm but it can 'dirty' the signal.
27.
INJ 1 control circuit Injector 1 output driver does not respond properly to the
or control signal.
INJ 2 control circuit Injector 2 output driver does not respond properly to the
or control signal.
INJ 3 control circuit Injector 3 output driver does not respond properly to the control signal.
possibly caused by the ASD being shut off... kind of a casualty of code 54, so to speak, or there is actually a shorted injector.
33. A/C clutch circuit... meh.. ... don't give it another thought...
