As far as air leaks go, since your plugs indicated a very rich condition, an air leak would need to make the ECU push fuel to a rich condition. Air sucked into the intake manifold will cause a lean condition. Air sucked into the exhaust manifold will cause rich.
I have heard of a few XJs having clogged cats. I'm sure that would cause poor running, but its not obvious to me that it would cause a very rich condition.
If it is running rich (map hose unplugged) its running fine, and i guess thats the reason the plugs were black, they had 50-100 miles on them and all of that driven time without the map -> running rich
The issue exists just if the Map hose is plugged in, wich leads me to believe its running to lean thats why im leaning toward a vacuuum leak (somewhere around the intake manifold) the whole vac harness is new
So youre saying if i had a crack in the exhaust manifold that would cause a rich condition?
I thought about ripping out the cat and looking inside, i just fear i dont get it out without damaging it
