dukie564
- Aberdeen, MD
Finshed drilling out the center pin holes and couldn't resist a mock up
Those are exactly like the leaf clamps I made, and mine sucked.
Too tight, they bound up the pack.
I would suggest welding that to the bottom leaf, and leaving the bolt somewhat loose.
NO! Do NOT weld to the leaf pack. It will become brittle and most likely break around the weld. Spring steel does not take to well to welding.
That's because you're supposed to put a sleeve where the bolt goes through so it doesn't crush the springs.
Just get some pipe from home depot or something and make some sleeves.
Cheap and easy.
