EMTJeepers
NAXJA Member #910
- Montague, N.J.
Maybe I'm not searching for the right things, but I just can't find information on the below problems. 99 Sport
1. Front Blinker/running light. Inside/Passenger side. Seems to be a plugin replacement, but can't find the part. I think it has 95023L on the part, but the stealership can't find reference to it... How do I replace it?
2. Heater control. It seems that the vent(?) is stuck closed and doesn't allow the heat through? I though vacumn, but when I took the controls off, it is electronic. I eventually get heat, but I can tell something is not open. I replaced the controller that controlls the fan speed, it was rusted out, is there something else I need to look at?
3. Idle... It doesn't Idle up anymore when it is cold? TPS???(Throttle Position Sensor?)
Thanks Guys & Gals...
Kevin
Kevin
