Help please, parts needed ASAP!
BadlilXJ
Lewistown, Pa
Well the lift finally got finished and when it went for alignment I got the bad news. It basically needs the entire front rebuilt and funds Are low. Here's what I need if anyone can help,
Hub/wheel bearings,
complete steering(tie rod and draglink with all ends)
all upper/lower ball joints
Rusty's track bar bushings.
Let me know if you have anything, stock is fine or aftermarket!
Let me go check my pile. I might have the stock steering.
well I have it, but I must have not been able to get the nuts off the TREs so I cut them. I have a factory track bar and bracket if that helps.
It's verified, the only thing I found that feels/looks good is the track bar. But I found more problems that needs attention first with the rear axle bearings being bad. See my recent post, this whole project is starting to piss me off and about to be scrapped!!!! I knew I would have to replace stuff but NOT everything right off the bat!!
I have stock steering
Junk the jeep and the zombies win, project AWOL
i have a hub bearing or 2 laying around just gave my last stock steering setup to a local person in need....sorry i didnt catch this thread sooner
