- Port Orchard, WA
RNMedic said:are you getting spark to the dist? are you getting spark at the plugs?
power to coil nothing past that
good coil
what plugs into the coil and controls it?
so i have a bad computer? great!langer1 said:
RNMedic said:okay look at this wiring the yellow wire in is from the ECU and this is the signal from the CPS, If you have power to the coil and no power out AND you know the coil that you replaced was good then something in there is an issue I would go with the ignition module right below the coil. I don't think it is the cam sensor cos you ain't getting juice in the Dist therefore no juice out. If this image doesn't come up then someone will need to tell me how to post PDF files, John.. Good Luck I'll email it to you
old_man said:Hope that was a joke.
