When I had cylinder washout, it was because I had tried to crank it so many times while the
CPS was bad, that it washed the cyl walls clean and compression went to 0...
It had been running perfect when I shut it down the nite before. Never used any oil between changes.
The temp outside was near 0 that night. The CPS gave up because of the cold temps.
This was before my
![NAXJA Smiley NAXJA NAXJA](/data/assets/smilies/naxjasmiley.gif)
days. I called a pro mechanic and we are both scratching our heads.
He ran a compression and ALL 6 cyls read 0, yes 0, After towing it to the shop and over $300 later.
Thinking it might be the timing chain/gears.
We talked to another Jeep mechanic that told us it sounded like cyl Washout.
Well, The jeep got warm in the shop and the CPS came to life again, un-beknown to us at the time.
We took an oil squirt gun and quirted 2 squirts of reg eng oil in each cyl and replaced the plugs and turned the eng over about 3 revelutions.
Rechecked the compression and it had come up considerably. We did that 2 more times and the
compression came back up to normal, I forget the exact numbers, (getting OLD) We replaced the plugs and it fired right up.
Found out later what caused the washout, WAS the CPS. It finally give up completely.
Turned out, a wire in the CPS harness had seperated. NOT evident looking at it, NO melting, NO cracks.
We took 2 large needles and pinned each end of the wires and checked with a OHM meter to find the break.
This may or may NOT be your problem. The CPS plays tricks on you. Sometimes U got fire to the plugs and sometimes U don't.
Still, it could be the COIL, but I would lean toward the CYL WASHOUT and a intermittant CPS.
GOOD LUCK!
