Hello
, I am a first time jeep owner, I just got a 1997 4DR XJ AW4 4.0L for free. It's in fair shape. The Bad is horrible case of death wobble, non working windows, non working rear hatch, blown struts, mostly all bushings worn out. The Good is engine and transmission quiet, smooth and solid, and only few small spots of body rust. It already had a poorly done 3-4" lift on 32s which I think likely contributed to all suspension components being worn so badly.
In first week of November we are expecting our second child, so my goal for the jeep is to have a safe daily driver that can fit two car seats in the rear.
2-2.5" lift on either 30 or 31s daily driver.
Here are all the parts that have arrived at my door step so far:
bilstein 5100s (24-185622 front, 24-185-639 rear)
crown +1" 190lb coils (52088104)
+1.3" 2x coil isolators (ENE-2.6103G)
crown +1" HD leafs (4886186AA)
+1" rear shackles (ZO J5107)
Currie HD Tierod and draglink (CE-9701)
rs7000MT stearing stabilizer (RS7401)
Adjustable Trackbar (JKS OGS126)
RE adjustable lower control arms (RE3715)
sway bar links (ZO J5300)
energy suspension sway bar mount (ENE-9.5161G)
stock replacement bump stops + 2x hockey pucks
Above parts probably totaling around $1500
Open to any tips or suggestions you might have as far as achieving my goals as noted above. Thanks all!
