Check your blower motor resistor pack and its connections. It's a kind of resistor block that gives resistance in multiple steps resulting in different speeds. It's location is on the passenger side plenum recirculated air intake. You can't miss it there's a plastic grate with a flapper valve attached to a vacuum motor. If you have haynes manual #50010 it's depicted on page 3-8. Hope this helps.
Mark
