- Westminster, SoCal
It'd probably have to be some sort of ceramic based stuff, but I don't think I saw anything like that in stores. So can anyone think of anything cheap (and easy to apply like rattle can based) that would do the trick?
Yeah, that's what i was looking for!!! I'm actually looking at it for couple aplpcations:AJsArmor said:Not exactly sure what you want it for, but if you've stripped your interior down to nothing, THIS STUFF works really well. At $90/gallon it's a really good buy, coverage they state is 50-60 square feet at a 15mil thickness. I put on about double that on the interior of an extended cab toyota, not only did it sound as quiet as a Caddy from the dampening characteristics but made a big difference thermally too. Blast the AC and come back out a bit later, still felt cool. In the winter it retained heat much better...
jjmat3 said:AJ, What color is the stuff and would it make a good replacement for a Rhino style coating for interior use?
Abugarcia said:
Where do you see the additive? I can't find itSpanky414 said:If I didn't already have some bedliner purchased I would think about some of that hy-tech stuff.
But they do have the paint additive, I think I might try some of that, its only $12 bucks for enough to mix with 1 gallon.
