Guys with 8lug Ford fronts, need a measurment
TPI MJ
Wooster, OH
What's the distance from the center of the yoke to the center of the cast pad on the driver's side? Also, what year is your axle?
Trying to figure out all all the front leaf folks get their front hangers under the frame. It looks like I'll have to outboard mine. I'm using a 60 front a late 80's F350.
Are you trimming?
CRASH
*edit*
Trying to figure out how all the front leaf folks get their front hangers under the frame. It looks like I'll have to outboard mine. I'm using a 60 front from late 80's F350
78 and 79 F-350 (some 250's) are the axle of choice. Newer ones were more offset to the drivers side.
TPI MJ said:
Trimming what?
Um, the axle?
Let me rephrase. Are you cutting down the axle or running full width? If you are narrowing the housing by 3" or so, the hangers fall into place perfectly.
CRASH
If that was unclear... the 78-79 ford dana 60's have a narrower leaf perch width, that is the same width as the cheroke uniframe, and YJ frame.... so they are expensive and hard to find.
download.php
